1999 Ford Ranger Spark Knocking
1999 FORD RANGER
ONGAIS
Engine Performance problem
1999 Ford Ranger 6 cyl Manual 90.000 miles
I have a 3 Litre V6, The PCM has been updated, I have had the injectors cleaned and valves decarboned and it still spark knocks on any fuel octaine. I have even changed the spark plugs. The dealer has no solutions for me.
Thanks
Dan
Jul 22, 2010 at 9:14 AM
MERLIN2021
  • 17,250 POSTS
If the Dealer has run out of options, I assume the check engine light is off? Check the cooling system by using a cooling system tester, pump it up to the rating of the radiator cap, or cap on the recovery bottle. if the prssure doent hold, it has a leak, and could be internal at a cylinder head gasket, it does not need to be a large leak to cause the ping... or buy a block test kit and test like this:
http://www.rxauto.com/demo.htm
Jul 22, 2010 at 1:11 PM
