PCV valve location
1999 FORD RANGER
CHICAGONUT
Six cylinder two wheel drive automatic 100,000 miles.
I am trying to locate my PCV valve. Where is it? What does it look like?
Apr 28, 2008 at 9:49 PM
98RANGERXLT
  • 301 POSTS
is it 3.0 or 4.0?
Apr 28, 2008 at 10:34 PM
CHICAGONUT
It is a 3.0. Thanks.
Apr 28, 2008 at 10:36 PM
ROB2008
  • 258 POSTS
The PCV valve should be located under hood, center, upper engine area, top of engine, mounted in driver side valve cover. Check the PCV valve frequently to see if it is free and not gummed up, stuck or blocked. To check the valve, remove it from the engine and shake it. It should rattle. It is possible to clean the PCV valve by soaking it in a solvent and blowing it out with compressed air. This can restore the valve to some level of operating order. This should be used only in emergency situations. Otherwise, the valve should be replaced at least once a year. Always check PCV valve hose for wear or cracks during service procedure. Removal and installation: Remove the PCV valve by simply disconnecting the vacuum hose from the valve, then pulling the valve from the rocker cover grommet. Click image to see an enlarged view.
https://www.2carpros.com/forum/automotive_pictures/181498_0900823d800b868b_1.jpg
Fig. 2: Remove the PCV valve from between the hose and the valve cover grommet.
Apr 28, 2008 at 10:55 PM
