1999 Ford Ranger No turn signals
1999 FORD RANGER
199,000 MILES • 6 CYL • 4WD • MANUAL
JAMES ARNETT
Currently I don't have any turn signals, though I do have Hazard signals. All four lamps flash with the hazards on so I know the lamps are good, but when I turn on the right or left turn signal I got nothing. No signals on the dasboard, no relay noise nothing at all. I did replace the relay according to Haynes it jst one relay for both hazards and signaling. I also check the fuse.
Any other ideas i could try??
Frusterated Jim
Dec 29, 2009 at 5:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if flasher unit (located behind left side of dash) was tested OK then suspect faulty multifunction (turn signal) switch.
Dec 29, 2009 at 7:17 PM
