is there a way to tell if a engine vibration is from harmonic balancer or motor mounts
Jan 9, 2008 at 8:10 PM
CERTIFIED EXPERT
Best way to check is to check them whether they're loose or worned-could be the ignition misfiring or a driveline/ transmission problem.
Jan 9, 2008 at 8:47 PM
FORDTECH
MEMBER
1 POST
To isolate a vibration, check your oil level first to make sure your not overfilled. If ok, remove accessory belt to isolate those components. If vibration remains, you may have a base engine concern (compression) mounts (isolate mounts one at a time).
