1999 Ford Ranger Head Gasket
1999 FORD RANGER
209,000 MILES • 4 CYL • 2WD • MANUAL
ABC000
Hello:
I can smell raditor coolant in the cab/passenger compartment & dash board tempature guage shows the engine is hot above normal. I see no coolant leaking inside or out. Could this be a head gasket or thermostate problem?
Thanks for your help.
abc000
Aug 20, 2010 at 5:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
If you can smell coolant and the temperature is rising than there is definitely a leak. If there is no visible leak than check the engine oil. If it looks milky than the coolant is probably leaking through a faulty head gasket. If the oil is good than the heater core behind the passenger dash may be the culprit.
Aug 20, 2010 at 5:36 PM
