1999 Ford Ranger Clutch Noise
1999 FORD RANGER
AMEGA84
Transmission problem
1999 Ford Ranger Four Wheel Drive Manual
I am having problems with my Ranger, It is making a grinding noise and is hard to shift into gear, especially first gear. The noise is not a constant, it is getting worse with time. Sometimes at a stop light, I can not get it into gear, and I have to turn off the truck, and restart the engine to allow me to get it into gear. The grinding noise is only present when I am sitting at an idle. Do I need a new clutch assembly or what?
Feb 28, 2009 at 6:53 PM
MASTERTECHTIM
  • 4,750 POSTS
sounds like the clutch is low on fluid. double check the reservoir for fluid. if you pump up the pedal does the clutch feel tighter?
Feb 28, 2009 at 7:33 PM
