99 Ford Ranger, 4 Cylinder, Fuel injected, Auto Tran. milage is 99870, standard cab, Air cond. power steering. Has two coils and wires on plugs.
My question is this, the engine appartently is from Mazda as it has the 2 plug per cylinder configuration.
I was able to change the plugs on the pass. side of the engine with no problem, other than they were hard to get to. On the drivers side I was able to get the first one, but have no idea on how to get the other three replaced other than removing the manifold as it appears that all three plugs on this side are under the intake or throttle body. Is there an easier fix than doing that? Or do you have to dismantle the top of the engine to replace those three plugs?
Thanks
Jerry
Thanks
Jerry
Oct 12, 2007 at 8:35 PM
