1998 Ford Ranger turn signal malfunction.. is there a flas
1998 FORD RANGER
SPUE
Electrical problem
1998 Ford Ranger 4 cyl Two Wheel Drive Manual 146k miles
the blinkers quit working and i just want to check the flasher, but i can't find it! the owners manual says nothing about a flasher relay and i don't see one in the fuse box or power dist. block under the hood either?
does this vehicle not have a flasher? do the blinkers work some other way?
Nov 14, 2009 at 10:19 AM
OBXAUTOMEDIC
  • 3,711 POSTS
The flasher is located under the driver dash on I/P Fuse Panel. If your were looking for the typical round one don't the newer ones are square. Also some of the newer vehicles have intergrated the Hazard and Turn.
Nov 14, 2009 at 10:30 AM
MERLIN2021
  • 17,250 POSTS
Inside fuse pane, fuse #21, 15amp
Nov 14, 2009 at 10:33 AM
SPUE
[quote:a1ba5dcb03="obxautomedic"]Hello,
.[/quote:a1ba5dcb03]
there are lots of square relays under the hood in the power distribution block, but none of them are identified in the owner's manual as being a flasher or having anything to do with turn signals or lights.
the passenger compartment fuse panel (under the dash?) has no relays. did you mean there's more fuses and relays UNDER the dash, that can't be seen without removing the dash or something?
Nov 15, 2009 at 5:32 PM
SPUE
[quote:42ab2cb7ff="merlin2021"]Inside fuse pane, fuse #21, 15amp[/quote:42ab2cb7ff]
this fuse is fine-
while it is labeled 'flasher' in the owners manual, i'm still looking for a flasher...
Nov 15, 2009 at 5:34 PM
OBXAUTOMEDIC
  • 3,711 POSTS
The flaher should be somewhere around the underdash fuse panel not in it. I haven't been able to locate a diagram to show the exact location.
Nov 16, 2009 at 1:41 AM
