WHEN I GO TO PUT THE TRANS IN GEAR IT MAKES A GRINDING NOISE JUST BEFORE IT GOES IN GEAR. AND IT MAKES THE SAME GRINDING NOISE AS IM RUNNING UP THROUGH THE GEARS WHEN I TAKE OFF FROM A STOP. IT ALWAYS DOES IT JUST BEFORE IT GOES INTO THAT GEAR. ALSO IF I AM SITTING STILL IN NEUTRAL I PUSH THE CLUTCH IN AND IF I LET IT OUT SLOWLY WHEN IT REACHES THE HALF WAY POINT IT WILL MAKE THE SAME NOISE. ANY IDEAS
Sep 19, 2009 at 10:02 PM
