How do you remove the center nut holding the alternator pulley on? Is it reverse thread?
Also, are the ballbearings on the alternator shaft usually OK, after pulling them off w/ a pulley puller?
I am trying to replace the slip ring, as it is worn down to the white plastic in areas (have slip ring & new brushes). Will need to find a pulley puller?
WAB
WAB
Nov 10, 2008 at 6:21 PM
