1998 Ford Ranger
1998 FORD RANGER
11,400 MILES • 6 CYL • 2WD • AUTOMATIC
CHILD0FDECADANCE
ok so heres the deal. my truck was running fine and then one day i came to a red light and noticed that upon idle it seemed like the truck was close to dying. so when i got home i turned off the truck, and tried to turn it back over. didn't work. later that day i went to turn it over again this time it turned over fine. i shut it off with in a minute and went to turn it over but it didnt turn over unless i was at wide open throttle. im thinking something is wrong with the fuel pump but im not sure
Mar 9, 2009 at 5:09 AM
RANGERDANGER17
  • 224 POSTS
when you have fuel problems giving it more gas makes it shut off faster that sounds like either a ignition problem or a stopped up exaust
also a clogged air filter or exuast pipe will make it not run well while hot
Mar 10, 2009 at 9:16 PM
