1997 Ford Ranger power sterring line access
1997 FORD RANGER
137,345 MILES • 4 CYL • 2WD • MANUAL
REZIN
Hi I am trying to get the pulley off the power steering pump but the pulley disc is in the way and I cannot get the two bolts backed off all the way to get the pump off and access the line bolts in the steering rack ....I've inserted the allen wrench to the round center bolt piece but the rest of the srepentine assembly turns when I torque down ........how do I stop it from turning? And is there a belt tensioner on the ranger to help take the belt off .......please let me know ....would be awesome advice thanks.
Jul 10, 2009 at 12:06 PM
2CARPRO JACK
  • 11,533 POSTS
It requires a puller to remove the power steering pulley, so that you can access the bolts. Most Parts stores will have them or will rent one to you.It will require an installer as well.Im not sure what you mean about the belt tensioner.
Jul 10, 2009 at 2:17 PM
