1997 Ford Ranger Clutch
1997 FORD RANGER
86,907 MILES • 6 CYL • 4WD • MANUAL
COOLAUTOCARE
  • 8 POSTS
Hi i did some modification on 97 ranger converting from automatic to manual using all ford parts form another ford truck.Except i bought new clutch kit including master and scave cylinder .problem is i bleed it a hundred times but can seem to get enough clutch .
Jan 31, 2010 at 6:03 AM
KHLOW2008
  • 41,814 POSTS
Hi coolautocare,
Thank you for the donation.
After bleeding, was there any signs of air trapped in system?
Did you check the pedal to master cylinder push rod clearance?
Jan 31, 2010 at 6:49 AM
COOLAUTOCARE
  • 8 POSTS
There seem to be no air in the system, there is any way i see that the clutch can be adjusted.But when i presss the clutch you can feel it starts to presure about half way down .
Feb 1, 2010 at 5:54 PM
COOLAUTOCARE
  • 8 POSTS
I did compare the measurment between the old rod and the new one and it is the same
Feb 1, 2010 at 5:56 PM
KHLOW2008
  • 41,814 POSTS
Should not be a fault with the hydraulic system.
Comparing the length of the push rod is not the correct way. You need to check the free travel before the push rod starts pushing the master cylinder poistons. If it is too far, the travel would be low. If the clutch is rather new, it would be rather low.
Are you able to shift into gears? If yes, how far does it release before the clutch starts to catch?
Feb 2, 2010 at 6:03 AM
COOLAUTOCARE
  • 8 POSTS
No Sir i cannot shif into any gear when the engine is start. How ever if i start the vehicle in gear while pressing the clutch the vehicle tryes to move a little .
Feb 2, 2010 at 4:21 PM
KHLOW2008
  • 41,814 POSTS
Do you understand how to check/adjust the clutch pedal to master cylinder free travel?
Feb 3, 2010 at 8:22 AM
COOLAUTOCARE
  • 8 POSTS
To be onest, no i dont have any experience the these types of clutch.
Feb 3, 2010 at 11:12 AM
KHLOW2008
  • 41,814 POSTS
Ok, I willl try to describe it as best as I can.
The free travel means the amount of clearance before the push rod pushes on the master cylinder piston. If it requires the clutch pedal to travel far before it pushes on the master cylinder piston, the clutch pedal would be verly low and you would not get sufficient movement of the clutch fork to release the clutch completely.
Loosen the push rod lock nut and lengthen push rod by turning it out until a slight resistance is felt, indicating there is no free travel of the push rod. Turn the push rod back 1/2 a turn to get the free travel and relock the locking nut. Retry if the clutch works.
If your clutch master cylinder is not equipped with any adjustment for the push rod, then you need to check the pedal height.
Feb 3, 2010 at 11:19 AM
COOLAUTOCARE
  • 8 POSTS
The reason i said i did nt have any experience with these type of clutch is because it doesnt have any adjustment and it has the internal slave cylinder .
Feb 4, 2010 at 5:02 AM
COOLAUTOCARE
  • 8 POSTS
Any sugestion yet?
Feb 5, 2010 at 3:29 AM
KHLOW2008
  • 41,814 POSTS
Sorry for the delay.
Did you check the pedal height?
Are the clutch master cylinder and slave cylinder of the correct type and size?
Feb 5, 2010 at 7:10 AM
COOLAUTOCARE
  • 8 POSTS
Its a orignal pedel from a ranger and the height is ok
Yes it looks the same as the old one .
Feb 5, 2010 at 10:46 AM
KHLOW2008
  • 41,814 POSTS
The size of the master cylinder should be embossed on the master cylinder and if it is a smaller size, which would vary slightly, it would require more movement to move the clutch fork.
Apart from that I can't hink of any other possible causes of insufficient clutch fork movement.
Feb 5, 2010 at 11:04 AM
