1996 Ford Ranger Odometer problem
1996 FORD RANGER
GALAXYHUNTER
Electrical problem
1996 Ford Ranger 4 cyl Two Wheel Drive Manual
I have a 1996 Ford Ranger with an odometer problem. I replaced the instrument cluster and it worked briefly and then quit once again. I went to a local AutoZone to see if there was perhaps a sensor that was the problem, They told me it used a cable, but when I replaced the cluster there was no attachment for a cable that I was aware of. The speedometer works just fine, at this point I am stumped here. Any ideas? Any help would be appreciated. I did notice that in an earlier post about having to drop the fuel tank to replace the pump, way to much trouble. Simply take the 4 or 6 hex bolts out of the bed and get a friend to help lift the bed off the frame and there she is, easy to get to. I have had to do it this. The bed is relatively light but kinda bulky.
Feb 22, 2009 at 1:21 PM
KHLOW2008
  • 41,814 POSTS
Hi galaxyhunter,
Thank you for the donation.
The speedometer and odometer uses the same signal input from the speed sensor and your symptoms description indicates a faulty gauge. Did you replace with a new or used meter cluster?
The data I have shows the speed sensor is electrical.
Doesn't removing the bed involves disconnecting wire harness etc?
Feb 23, 2009 at 2:22 PM
GALAXYHUNTER
I replaced the cluster with a used one from a salvage yard. Can you even get a new one anymore for a 1996 model? I figured it was a sensor rather than a cable. As far as the bed is concerned, yes there is a harness to disconnect but is very easy to do. I dreaded dropping the fuel tank so I took the bed off instead.
Thanks for the reply, I appreciate it.
Feb 23, 2009 at 4:21 PM
KHLOW2008
  • 41,814 POSTS
Since it is a used meter, I believe you can get a replacement as the purchased one seems faulty as well.
New meters should be available at the dealer but it is not going to be cheap.
So a great job done on the fuel pump replacement. Cheers.
Feb 24, 2009 at 7:04 AM
GALAXYHUNTER
Thanks for the advise, this is a good place for info you need. I will check into new instrument cluster.
Take Care!!
Feb 24, 2009 at 7:49 AM
