1996 Ford Ranger ignition actuator
1996 FORD RANGER
147,000 MILES • 4 CYL • 2WD • MANUAL
SHAWNTE
I was needing to find a diagram/schematics of how to replace the ignition actuator on my 1996 ford ranger 2 wd 4 cyl. any information that can be provided for my problem would be very much appreciated
Jun 10, 2008 at 12:35 PM
BMRFIXIT
  • 19,053 POSTS
Ensure gear in park set E brake on
remove steering column shrouds
disconnect key warning switch electric connector
Using pin turn lock cylinder to run
using a 1/8" diameter pin depress retaining pin located in lock cylinder housing and pull out lock cylinder
http://www.2carpros.com/forum/automotive_pictures/99387_ford_key1_1.jpg
Jun 12, 2008 at 6:13 AM
