It sounds like a banging in my Transmission, most especially when I down shift but also sometimes when I go in reverse and sometimes Even when Im starting out in 1st gear....but most notably when I have downshifted. I do not notice a change in RPMs or much vibration through the shifter. Upon closer inspection I have noticed some play in the driveshaft and the sound it makes when I manually (with my hand) work the play in the drive shaft sound like what I am hearing as I downshift. Im not sure if the play is in the Trans or the rear differential.
What would cause this play and how might I be able to fix it?
Dec 2, 2008 at 2:51 PM
