1995 Ford Ranger ratleing
1995 FORD RANGER
130,000 MILES • 4 CYL • 4WD • MANUAL
ROBOTOPHER
  • 10 POSTS
my 1995 ford ranger with 130000miles has a wierd rattling problem in mid area of the exhaust. when ever i rev my engine up kind of high something starts to rattle inside of the exhaust but i dont know how it got in there. i dont want to have to take it in to get it fixed and i dont know what it is. is there any ideas of what it could be and how i can get it out
Feb 18, 2008 at 11:29 AM
MERLIN2021
  • 17,250 POSTS
What you are describing, if not an external heat shield will be the "bed" or internal part of the catalytic converter has broken up and is the pieces that are rattling! Check the welds on the converter heat shields first, then rap on the converter and the pipes with a rubber mallet, you will hear whats wrong then....
Feb 18, 2008 at 11:40 AM
ROBOTOPHER
  • 10 POSTS
well now that i know where and what it is how exactly do i get it out?
Feb 18, 2008 at 4:15 PM
MERLIN2021
  • 17,250 POSTS
Depends on whats going in...a direct fit requires the entire piece to be removed, a universal, you use a sawzall, cut right before and after the converter, then weld the new one in...if you have determined it's the converter.
Feb 19, 2008 at 7:16 AM
ROBOTOPHER
  • 10 POSTS
so i have not exactly determined that it is the converter and even if it was i cant weld because i do not have a welder or a license. would it just be easier to just replace my whole exhaust?
Feb 19, 2008 at 6:04 PM
