1995 Ford Ranger front axle
1995 FORD RANGER
DANA WILLETT
Suspension problem
1995 Ford Ranger 4 cyl Four Wheel Drive Manual
How do i pull the left front axle drivers side i think the joint or universal is bad in 4 wheel drive if i turn the wheel very sharp it locks up
Sep 9, 2008 at 5:39 PM
BLACKOP555
  • 10,386 POSTS
you will have to remove wheel, rotor, bearings. then remove the spindle, then you can pull the shaft off. check the universal joints before you condem them of the problem and go through the hassle.
Sep 9, 2008 at 7:27 PM
