1995 Ford Ranger connection for code scan
1995 FORD RANGER
117,500 MILES • 4 CYL • 2WD • MANUAL
JJJRSTEVENS
I have read that the connection for the code scanner is under the dash for my 1995 ford ranger. I cannot find it. The repair manuals are vague. Can you help.
Sep 27, 2008 at 10:37 PM
BMRFIXIT
  • 19,053 POSTS
yours is not an OBDII ready
check under the hood for the connection
Sep 27, 2008 at 10:43 PM
JJJRSTEVENS
I did find the plug for the scanner. The thing that is driving me nuts is that the 1995 ford ranger with the 2.3 L engine is not what the manuals talk about. I do not have an external ignition control module, mine is intergrated with the pcm. The 1995s came OBDII ready. The 93-94 model rangers have the test connection under the hood. I am learning more and more about this truck as the days go by. Thanks for your help.
Sep 27, 2008 at 11:25 PM
BMRFIXIT
  • 19,053 POSTS
Again not all 1995 came with the OBDII
if you can not locate the DDL
also check in the passenger side area
Sep 28, 2008 at 10:34 AM
