Did you just install the wireing harness and is the pic below what you installed?
If the pic above is not what is installed that could be your problem. The harness above has a power modulator, I believe that what is it called. And without that in the loop the is to much power being pulled to the trialor and will cause the fast blinking. Its like it a bulb was burned out. If you look at the tail lights before hooking up the trailor notice the brightness, then hook up the trailor and again notice the brightness. The lights are dimmer than they should be causing the vehicle to think that there are bulbs burns out in turn causing the fast blinking.
Oct 19, 2018 at 6:24 PM
