1994 Ford Ranger Noise
1994 FORD RANGER
185,000 MILES • 4 CYL • 2WD • MANUAL
VOLSFAN458
I just had the transmission replaced on my 1994 Ford Ranger. Last year, I had the clutch replaced. The truck runs and shifts gears fine. However, it makes a chunking type noise in neutral. When I press the clutch in, the noise goes away. What might be causing it?
Jun 29, 2008 at 10:52 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Can you explain a bit more on the type of noise. Most likely it is a finger on your pressure plate; however it could be the hydraulic bearing/slave cylinder. Your clutch pedal feels firm and there is no air in the system correct?
Jun 29, 2008 at 11:45 PM
