1994 Ford Ranger fuel tank
1994 FORD RANGER
130,000 MILES • 6 CYL • 2WD • MANUAL
FRANSON
I replaced the fuel filler hoses from the inlet to the fuel tank. I filled the tank then drove it. When I attempted to put fuel in 300 miles later, the gas dispenser nozzle clicks off as if the tank is full. The gauge registers whatever I input, usually about 5 bucks then I can't add any more the nozzle clicks off. Fuel even backflows out of the tank. I tried different stations, same result. Is the tank full? But only registering 1/8 of a tank. I'm confused.
May 1, 2008 at 6:13 PM
BLACKOP555
  • 10,386 POSTS
sounds like the fuel filler hose is kinked off or was installed properly, or you bent or kinked the vapor line, go back and double check what you did, i dbout its 1/8th of a tank empty after 300 miles!
May 1, 2008 at 6:58 PM
