1994 Ford Ranger clutch/slave cylinder
1994 FORD RANGER
PROTOTYPE1
I recently replaced my 5spd trans in my 94 ranger with a low mileage rebuilt trans from a 1989. Trans is the same as one that was in truck. I ordered new clutch kit w/slave for 94. Slave was different (plastic not alum.) I was told it would not work so I purchased a new alum. unit. Put it back together and clutch would not bleed. Tried 30 different times and procedures, but still did not work. I then replaced master cylinder (pre-bled), still not working. I then replaced the new clutch/pp with the old ones (almost new), still nothing.
My questions: what are the differences in the 89 and 94 slave unit (plastic vs. alum.) other than the quick change fittings. Are the cluth and pp the same and/or interchangeable (part #'s are different but I was told it does not matter) What other methods of bleeding the system are there besides what the manual says.
Thank You for any advice to help end this frustrating problem.
Jim
Oct 23, 2006 at 6:23 PM
CATCH_15
  • 250 POSTS
Even if the parts are different in design, they should be the same in function. The new one should bleed. It's something that probably has to be seen to diagnose.
Oct 23, 2006 at 9:43 PM
