1993 Ford Ranger ranger clutch bleeding
1993 FORD RANGER
90,000 MILES • 6 CYL • 4WD • MANUAL
VEGADAN
  • 13 POSTS
i have a 93 ranger and i replaced the slave cyl and master cyl ,and the shop cant seem to get it bled all the way as i have grinding and is so hard to get in any gear,there must be a trick to this because i see it is some what of a common problem
Mar 29, 2008 at 7:12 AM
2CARPRO JACK
  • 11,533 POSTS
They are a PITA I usually pump the pedal by hand (since it stays down) many times, then open the bleeder. Pump the pedal, open the bleeder.Takes many tries to get all the air out
Mar 29, 2008 at 9:06 AM
