1993 Ford Ranger idle speeds
1993 FORD RANGER
175,000 MILES • 6 CYL • 4WD • AUTOMATIC
ROBERT ECCLES
idle somewhat erratic after warmup. about 900 to 1000, when shifting to drive or reverse the revs jump up 400 or so and cause a hard shift into gear....No codes are set...intake manifold leak checked with no leaks found. New iac installed and no help. any ideas????
Dec 23, 2007 at 8:45 AM
MERLIN2021
  • 17,250 POSTS
You have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak!
Dec 23, 2007 at 9:50 AM
