does this vehicle have a crankshaft posioning sensor
Nov 8, 2008 at 6:48 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Yes. It should be under the crankshaft pully. You need to remove the harmonic balancer and then you will see it. It has three little blocks on it. It should be on the RH side of the front of the block.
Nov 8, 2008 at 7:04 PM
CERTIFIED EXPERT
A 2.3L has it-on the 2.9/3.0/4.0 6 cylinders-the 4.0 comes with it-CPS
