[quote:45423a9c17="rangerdanger17"][quote:45423a9c17="rangerdanger17"][quote:45423a9c17="BMRFIXIT"]You need to check and make sure you have an oil pressure
you should not drive with no oil pressure or engine will be damaged
locate oil pressure switch and check if its any good
u can also remove it and check oil pressure throw it by hooking up a gauge and starting the engine
as for the noise
u may remove valve cover and check the rocker arms if u have collapse lifter or other issues
but oil pressure is the top issue no sense doing any thing without oil pressure
and if you have a lot of miles it maybe wise to get another good used engine
good luck[/quote:45423a9c17]
Okay thank you a lot[/quote:45423a9c17]
okay i got a new pump and a new pressure switch and gaskets for the oil pan and i the oil pan off
but i wont come it has bars and suspesion arms keeping it from falling to the ground the transmisson is too close to slide it that way and the suspesion arms keep it from going forward and there is something inside keeping it from moving sideways
the front suspenion arms are tied in on the same bracketas the engine mount
my question is how do u remove the oil pan
so that i can replace the oil pump[/quote:45423a9c17]
I got it but thanks alot
May 20, 2008 at 4:09 PM
