1990 Ford Ranger Truck keeps stopping
1990 FORD RANGER
169,000 MILES • 6 CYL • 4WD • MANUAL
SHAUNABAY
  • 8 POSTS
Starts up runs for a little bit, then dies, replaced pickup coil, not the problem, after replacing pickup coil ran for a little while, won't start at all. Could it be the coil, since it's not getting any spark at all? Please help......
Oct 6, 2008 at 2:56 PM
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic_11.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_3.jpg
I would suspect spark control module need manual CHECK IT @ https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 6, 2008 at 6:12 PM
SHAUNABAY
  • 8 POSTS
Replaced the ECM, replaced distributor cap, rotor button, ignition coil, now starts up, and shuts off. Started right up as soon as ECM was replaced. Haven't replaced the little silver unit next to the coil, with one plug on it, could that be part of the problem, and if so, what is that piece called? Thank you....
Oct 11, 2008 at 1:41 PM
BMRFIXIT
  • 19,053 POSTS
Its called ignition module (spark control module)
the picture above shows it
Oct 12, 2008 at 5:13 PM
