Drive Train Axles Bearings problem
1990 Ford Ranger 6 cyl Four Wheel Drive Manual
On my 90 Ranger, the clutch pedal has very limited disengagement. I cannot shift into any gears with engine running. If I start the truck in gear, I cannot shift out of gear (doesn't matter which gear). Upward movement of the pedal results in clutch engaging very quickly, within 1/2 inch of pedal movement. Is this the slave cylinder or master cylinder?
Sep 22, 2009 at 8:28 PM
