1989 Ford Ranger fuel pump location
1989 FORD RANGER
MOOSE49304
Engine Mechanical problem
1989 Ford Ranger 4 cyl Two Wheel Drive Manual 84.000 miles
i been told to look on the right inside fender to find the pump relay,but in some manuals it shows the map sensor and the fuel pump mounted on the wall,but on my truck there is power bus mounted on the wall there is no relays there,where else possible could this pump relay be?..thank you for your time...Help
Mar 16, 2009 at 11:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Your fuel pump relay is located on the right front fender panel on the relay block, pictured below..
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_2.jpg
Thanks for using 2CarPros.com!
Mar 17, 2009 at 12:40 AM
