1988 Ford Ranger Stuck in reverse gear
1988 FORD RANGER
85,000 MILES • 4 CYL • 2WD • MANUAL
GOALDENEYE
My old ranger pickup is stuck in reverse, my shifter popped out and from there its been stuck, was able to be towed while clutch was engaged. Now I can't even push it forward. What can I do to get'r back on the road? Thank you for your help :D
Mar 20, 2009 at 12:47 PM
BMRFIXIT
  • 19,053 POSTS
have to check the links
or its internal tranny failure
Mar 21, 2009 at 6:29 AM
GOALDENEYE
[quote:94a7ea0c7f="BMRFIXIT"]have to check the links
or its internal tranny failure[/quote:94a7ea0c7f]
Good morning, what are the "links"?
Mar 23, 2009 at 1:21 PM
BMRFIXIT
  • 19,053 POSTS
the shifter came out of the tranny
and it is in reverse
or it just stuck in reverse
remove the shifter arm boot and plate cover and check
you have to remove the shifter and place the tranny in neutral and then reinstall the shifter
Mar 23, 2009 at 6:12 PM
