1987 Ford Ranger Resetting Dual Master Cylinder
1987 FORD RANGER
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
PSYCHO42K
I had a rear brake failure, and I have now repaired the problem. However now I still have no rear brakes and the Brake Warning Light is on all the time. I suspect that the problem is in the dual master cylinder and I have no idea how to determine if it is working right or if it needs to be reset after the failure. And if it does need reset how do I do it?
Aug 26, 2008 at 9:58 PM
BMRFIXIT
  • 19,053 POSTS
DID U BLEED THE SYSTEM
U need to bleed the system get the air out
have a helper pump the brake and then hold down u open the bleeder
repeat until brake fluid flow with out any air
and u have a good brake paddle
make sure u stop and check the fluid in the master every few pumps
dont let it run out of brake fluid
good luck
Aug 27, 2008 at 3:07 PM
