1986 Ford Ranger right turn signal/brake light doesn't work
1986 FORD RANGER
138,000 MILES • 6 CYL • 2WD • MANUAL
HULSMAN
Recently my right turn signal and brake light quit working. I checked the bulb and it is good, and the socket looks fine as well. The funny thing is that when I turn the signal switch in the truck to turn right, the light on the dash just lights up and doesn't blink, whereas when I turn the switch for the left turn signal to come on the light in the dash blinks. Also, when I turn the right signal on, the front blinker just lights up and doesn't blink. The left turn signal/brake light work fine. Any help would be appreciated.
Feb 15, 2009 at 3:18 PM
BILLYMAC
  • 2,204 POSTS
hi the right brake light and sig .do you have 12 volts there with sig on. if no prob in right rear replace bulbs in front and rear. if this don,t fix prob you will need a new sig switch, good luck billymac
Feb 15, 2009 at 9:11 PM
