I have an old 1972 ford truck with the big block C-6 auto
transmission. It sat for about 3 years. I just recently started it up to check all the fluids. The transmission fluid was pink. Only guessing that it's water that got in through the dip stick not being completely closed. My question is this: after changing the fluid and filter should the friction plates (clutches) still be functional? Transmission was rebuilt with red alto eagle friction plates 200 or 300 miles before being parked. The truck will drive forward and reverse. The stall converter still engages normally. After the fluid change it seems to drag in acceleration. I was told to slowly break in the new fluid
and add some trans medic to get the fluid moving around through the valve body. Also told that the friction plates are possibly fried. What do you think?
Dec 4, 2007 at 4:37 PM
