OVERHEATING
FORD PROBE
SPARKY87
  • 4 POSTS
My 1995 Ford Probe SE, 4 cyl. 2 liter, will overheat just driving it around the block. I just replaced the water pump and it’s working. I replaced all the hoses, the thermostat and flushed out the radiator. Water seems 2 flow through every thing when it’s not put together, but if I put every thing together and start it, I can't get 300 yards with out it overheating. Help Please!
Mar 12, 2007 at 11:51 PM
CHEVY22
  • 1,375 POSTS
are the fans coming on at operating temps , and is your gage reading hot or the gage and the engine hot
Jim
Mar 13, 2007 at 2:18 PM
SPARKY87
  • 4 POSTS
The fan is turning on and the gage in the car is reading hot
Mar 13, 2007 at 6:40 PM
CHEVY22
  • 1,375 POSTS
is the engine hot , the radiator ??? gage could be wrong
Mar 13, 2007 at 6:42 PM
GEEE
did you havethis same problem before you replaced the pump. I have hjad new pumps on this type of vehical that the impeller was loose on the shaft
Mar 13, 2007 at 6:55 PM
SPARKY87
  • 4 POSTS
no the problem just started. so i took the water pump back out and its good. i herd that i mite have a air bubble in the bock. can this happen? and how do i get it out.
Mar 13, 2007 at 7:32 PM
SPARKY87
  • 4 POSTS
the radiator is warm and the engain is really hot
Mar 13, 2007 at 7:33 PM
