losing coolant out the overflow tank
FORD PROBE
TRICKBOARDER15
I called to check out a ford probe and the guy told me it throws antifreeze out of the overflow pipe after 10 mintues of running time. It's the 4 cylinder engine. it is a 93 to 97 body syle. The miles are 125,000.
Oct 29, 2007 at 6:48 PM
Could be the thermostat or the radiator cap needs replacement, bad water pump and clogged up radiator, collasped hoses, fan not coming On or fan clutch. Do below for a blown headgasket/crack head and block.
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Could also be air lock in the cooling system do below
BLEEDING COOLING SYSTEM
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks.
Oct 29, 2007 at 8:47 PM
