Ford Probe
FORD PROBE
BCUNNINGHAM
1993 Ford Probe, Miles 184149 v6 engine.
engine just quit,
noticed "fuel cutout" light on so I checked the fuel shut off valve in the rear.. it was ok ..
timing belt was replaced a few months ago and it has ran ok scince replacement although a little sluggish and fuel rich but ok .. not the same power as before replacement I belive they may not have it in perfect timeing.. but I do have compression and belt rotates.. I think it is getting fuel .. loosened the injector rack and turned over .. could not be for sure ... I checked for spark and did not get any .. I check for voltage at the distributer and had voltage on a couple of wires .. not sure where I should have it or what it should be.. Can anyone help me with this .. I have heard Ford had a problem with this but do not know the answer.. would be glad to donate more for the correct answer..
Thank you ... BC
Oct 6, 2007 at 1:55 PM
MERLIN2021
  • 17,250 POSTS
If you got no spark, check or replace the ICM, screwed to the side of the distributor...
https://www.2carpros.com/forum/automotive_pictures/62217_Probe_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_30961_mitchell_2_47.jpg
Oct 7, 2007 at 9:27 AM
