93 ford probe GT, KL-DE 2.5 L V6, i was cruising down the expressway and i noticed that my oil pressure was low, about 25 psi (i installed an aftermarket mechanical gauge) it is usually about 45 psi, so i pulled over and checked the oil it was fine, not low at all. well when i took off it was knocking at about 2000 rpm, i drove about another 4 miles and the motor locked up, now my question is can i rebuild this motor if it has thrown a rod or crank bearing. could i just remove the old bearings and put new ones in there as well as piston rings and a hone, and it would run fine or is there more involved in rebuiling a siezed motor. i am a mechanic working for a local repair shop so i have the knowlege on rebuilding i just dont know if i can rebuild this or not. thank you mike
Feb 19, 2007 at 9:51 PM
