91 ford probe a/c and heater fan won't work
1991 FORD PROBE
SPIDER6738
i have a got a 91 ford probe four cylinder automatic with 80,000 miles on it the a/c and heater fan won't do anything i have no power at the fan and the will work if i unplug everything and run a hot and ground to it. i took the speed switch out of the dash and only one wire is hot coming in i don't know if this is the way it should be or not the wire that is hot is a black and yellow striped wire it is the same wire that supplies the power to the a/c light (the only thing that works) some body please help me!!!!!
May 18, 2007 at 4:09 PM
RUDPRO
  • 224 POSTS
Did you check the fuses?
May 18, 2007 at 9:38 PM
SPIDER6738
yes i checked the fuses but still nothing
May 19, 2007 at 4:58 PM
