Engine Performance problem
1997 Ford Probe 4 cyl Front Wheel Drive Manual
I have a 97 ford probe The ignition timing wont stay constant, could it be the timing belt tensioner or is the crankshaft sensor out of adjustment, engine starts but idles rough, when I rev it up the engine will bog down instead of increasing rpms. when I put a timing light on it . the timing mark jumps 15 degrees at idle. need help
Apr 20, 2008 at 11:18 AM
