1997 Ford Probe New battery still dies.
1997 FORD PROBE
218,867 MILES • 4 CYL • FWD • MANUAL
TWISTDSHADE
I've been driving this car for about a year now.. off and on between me and my dad and it's mine now.
There have been two different batteries in this car that I know of, both of them used.
The last battery worked off and on, and more times than not we'd have to bump start the car even after driving around for hours..
After charging overnight, the battery was completely dead.. the radio screen barely lit up, and the horn wouldn't work.
I purchased a brand new battery from NAPA auto for about $80 which worked for about two days..
It powered my laptop the whole time, going 10 hours without starting the car up, no problems.
And today I had to bump start it again a few times...
Just now I tried to start it up, and it made an unusual clicking noise...
Guessing by the hit/miss of it all, I'd say there was a wire loose somewhere.. just need to figure out where.. I would probably be better off replacing all of the vital cables in the engine because of all of the wear and corrosion.. but how difficult would something like that be? and how expensive? where do I start?
Jul 2, 2009 at 11:52 PM
For a start load test the alternator might not be reconditioning the battery and also recheck battery connection make sure the posts/cables are cleaned and shiny and properly tightened. If it continues could be the starter, clutch switch, and ignition switch.
https://www.2carpros.com/forum/automotive_pictures/12900_probe_start_circuit_2.jpg
Jul 3, 2009 at 12:05 AM
TWISTDSHADE
There was a lot of buildup around the battery terminals.. cleaned that up..
Also I found that the ground wire was loose where it connects to the car's body..
After some more research I found that the clicking was most likely just another symptom of a low battery.
Seems to be working just fine now, thanks for the help!
Jul 3, 2009 at 11:17 AM
