1997 Ford Probe manual driver side window repair
1997 FORD PROBE
108,000 MILES • 4 CYL • 2WD • MANUAL
BILL DOWER
The window is down and the internal wire ropes are terminated but loose. How should the wire ropes be routed? What is the most likely cause of the failure? Do I have to repalce a part?
Jun 24, 2010 at 3:53 PM
2CARPRO JACK
  • 11,533 POSTS
If the cables are broken you will need to replace what is called the window regulator.This is the assembly that actually lifts and lowers the window.
Jun 28, 2010 at 8:03 AM
