1997 Ford Probe cuts out giving it hard throttle
1997 FORD PROBE
122,000 MILES • 6 CYL • FWD • MANUAL
RLAUBER54
i am a mechanic myself but this probe has got me baffled.. it starts and idles fine, and if you rev it up slow it'll rev up fine. but if you punch it, it'll hit like 2500 rpm and cut out. our scanner won't connect to the computer, its got a new distributor, replaced the TPS, fuel pressure is good, spark seems to be able to jump a good sized gap, we checked back pressure on exhaust, replaced o2 sensors, checked cam timing, everything seems to be in order. any thoughts?
Mar 26, 2010 at 7:19 PM
It sounds like you have hit about everything. Have you checked compression?
May 11, 2010 at 11:11 AM
