Hello -
Thanks for the info.
You can find your engine liter size on a decal inside the engine compartment. You need to know which size it is.....either a 2.0 or 2.5 since it may be different. I have attached both for you. You can also look at the 8th digit of your VIN. If it is a letter B then you have a 2.5L. If it is a letter A then you have a 2.0L.
Crankshaft Sensor for the 2.0L - circled in red. And it looks like there are two. See below.
CRANKSHAFT POSITION (CKP) SENSOR
Removal & Installation
2.0L has 2 CKP sensors. CKP sensor No. 1 is located in distributor and is not serviced separately. See DISTRIBUTOR. CKP sensor No. 2 is located behind crankshaft pulley. To Remove CKP sensor No. 2, disconnect sensor wiring near top of timing belt cover. Working from below, remove CKP sensor mounting screw and sensor. To install, reverse removal procedure. Adjust CKP sensor air gap to .020-.060" (0.5-1.5 mm). Tighten sensor screw to 71-97 INCH Lbs. (8-11 N.m).
Crankshaft Sensor for the 2.5L - now the problem with this one is they have it mismarked in the manual I think it should be the one I have circled.
1. CKP sensor is located on side front cover near crankshaft pulley. Disconnect negative battery cable. Remove serpentine drive belt. Raise and support vehicle. Disconnect sensor connectors.
2. Remove sensor bolt and sensor. To install, reverse removal procedure. Tighten sensor bolt to specification.
Aug 7, 2009 at 9:57 PM
