1996 Ford Probe Spark Plug Connector Sealing Lip
1996 FORD PROBE
155,000 MILES • 4 CYL • FWD • AUTOMATIC
DANIELMINTER
I was just replacing my spark plugs on my car and everything was going fine until I got to the last plug. The spark plug connector sealing lip has broken off the end of the rest of the connector and is stuck inside the spark plug hole. I cannot find a way of getting that out and I can't replace the spark plug until I can get that out.
Any ideas?
Jul 14, 2009 at 7:01 PM
AUSTIN78989
  • 17 POSTS
I assume you mean this part of the spark plug wires, I think if you take the rod and you push it back down in the hole you might be able to press the plastic sheath back into the rubber "sealing lip" If that doesn't work, you can try using some superglue, or a gentle adhesive on the tip of the plastic sheath and have it stick to the rubber seal, once its out you should be able to pop it back on.
I am no expert here, just saw your post and thought I would chime in. I have a 1997 probe gt.
Oct 20, 2017 at 9:23 PM
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Oct 21, 2017 at 11:44 AM
