I am doing a mini over haul - replacing the head gasket,timing belt,water pump. I have put it back together but I am not getting any fuel to the cyclinders. The fuel rail is full and pressurized. I check the volts at the injectors I get 12v. But if I turn the engine over there is no pulse. I changed the crank sensor what else can I check?
Oct 20, 2010 at 1:33 PM
