1996 Ford Probe egr sensors
1996 FORD PROBE
180,000 MILES • V12 • FWD • AUTOMATIC
TYOVAN
  • 4 POSTS
check engine light on for a couple days then off for a couple days about 2 months now codes p1195 (boost sensor)and p1402 (valve position sensor) can you help with locations and diagrams is the position sensor on the egr valve and the boost sensor on the air filter housing will 1 sensor set another off
Aug 18, 2009 at 11:43 AM
DOCFIXIT
  • 18,828 POSTS
2.0L or 2.5 L
Aug 18, 2009 at 11:52 AM
TYOVAN
  • 4 POSTS
[quote:9f24174cdf="Docfixit"]2.0L or 2.5 L[/quote:9f24174cdf]
Aug 19, 2009 at 9:16 AM
TYOVAN
  • 4 POSTS
its a 2.5 and I have manuels
Aug 19, 2009 at 9:26 AM
DOCFIXIT
  • 18,828 POSTS
Hi Both are located rear top center of engine. And yes either one fails can set code for other. Does your manual have instructions for testing EVP and Boost? See figures
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_81.jpg
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_18.jpg
Hope this helps
Aug 19, 2009 at 9:44 AM
