1995 Ford Probe washer
1995 FORD PROBE
SEASIDER69
Electrical problem
1995 Ford Probe 6 cyl Two Wheel Drive Manual 110.34 miles
my jet washer for windowscreen does not work..i have checked internal fuses.wipers work fine..
Dec 21, 2009 at 8:20 AM
BLUELIGHTNIN6
  • 16,542 POSTS
test the washer pump. unplug connector from washer pump. connect black wire terminal of pump to ground. connect blue/orange wire terminal to battery voltage. replace the washer pump if it does not run.
Dec 29, 2009 at 1:11 AM
