1995 Ford Probe car won't turn over
1995 FORD PROBE
112,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKE GEIS
car won't turn over has no spark I let it sit for a day or two and it fires right up,help.
Apr 28, 2008 at 3:56 PM
When was the last time you had it tune-up ? also double check all the ignition components connection-
Or you can try below to determine if its fuel or spark
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
Fuel pump and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Apr 28, 2008 at 4:01 PM
