1994 Ford Probe rough idle
1994 FORD PROBE
26PHIL
Engine Performance problem
1994 Ford Probe 4 cyl Front Wheel Drive Manual 178xxx miles
the car starts fine but sometimes when i come to a stop sign or stop light it idles rough it acts like it wants to shut off. I did notice when i changed the spark plugs there was oil on them do u think i should replace the valve stem seals.
Jan 3, 2010 at 7:32 PM
RACEFAN966
  • 5,029 POSTS
The oil was on the outside of the plugs right? If that is correct then you need a new vavle cover gasket that includes spark plug seals. Here is a pic of the gasket. Then I would replace the spark plug wires if they are covered in oil.
https://www.2carpros.com/forum/automotive_pictures/249564_612303_1.jpg
Jan 4, 2010 at 12:16 PM
BLASTO
  • 5 POSTS
If car runs rough only at idle, it's unlikely to be the leads. I would check the TPS. Yes, you have an unrelated leaking VCG, they last about 5 years or 30000km.
Jan 5, 2010 at 5:38 PM
